Samuel Des
- Feb 7, 2001
My receiver will occasionally emit an odd click, a sound that is similar to the snap from static discharge. The click is not transmitted to the speakers, but seems to be generated within the chassis. This occurs whether the receiver is on or off; it does *not* seem to occur when I unplug it, or turn off the master switch. The frequency with which the snap-click sound occurs seems to be increasing. (Though I cannot say for certain.) Is this sound a symptom for a developing problem? Or is it simply a sign of normal usage/wear-and-tear/whatever?
Sam
[Edited last by Samuel Des on August 29, 2001 at 12:40 AM]
Sam
