Wayde_R
- Aug 25, 2003
If I get a projection TV, is there a particular choice or video input style I should consider for using with a PC?
Are the fixed pixel display types better for operating windows from your couch (my ultimate goal)? Will a crt based RPTV work just as good? Should I look for DVI or HDMI or are there video cards out there with component outputs?
The other part of my question is that I know it's not as simple as finding a video card with the DVI or HDMI out to plug into a TV w/ a corresponding input. What converts the PC video into something a TV can display as clearly as possible?
Any advice or point me in the direction of reading. I know too little to narrow my questions into simple searches.
