Newbie Question (1 Viewer)
Marshall A
I'm trying to find a decent wireless ( rear speakers ) system with a decent dvd recorder and I'm not finding what I want in a pre-packaged box. This seems to be the best combo I've found to put together:
Sony DAV-FR10W wireless Home Theater system
Panasonic DMR-E55K DVD recorder
Would these components be compatible..??
Any input would be greatly appreciated...??
Dean_S
Kenwood and Radio Shack both sell Wireless amps which allow you to use your own speakers. I have the Radio Shack amp and it works well. I didn't like the sound of the wireless speakers I found, so went this route and used the speakers that timbre match my fronts. The RS amp retails for $100 and is 25w/ch, the Kenwood is probably better and retails for about $150 and is rated at 50w/ch.
Nielmb
