DanielGM
- Jul 15, 2003
hey guys,
I'd like to think I know a good deal about audio, but this will be my first DIY attempt, unless you count a pair of flexy speaker stands and a flexy component rack
I was originally thinking of going with building my own enclosure to mimic the Stryke Power 15.6 (2 15" drivers, 6 15" PR's) But for cost and simplicity I think I am going to try and build something like a Revel Sub-15 using a stryke AV15. Possibly not the best first choice for DIY, but personally I would rather not waste my time building a boring black box, and if it takes me till next summer to finish it then so be it, as long as I am happy with the performance and aesthetics. I am sure this thread will encorporate more questions later but for now the ones I am starting off with:
1) I am using winISD to graph the output and I am getting a -3dB point of around 35 hz? (is this the f3, btw?)
can someone comment on whether I am doing this right? You can find the box dimensions on page 36 of the owner's manual: http://revelspeakers.com/PDF_manuals/sub15le1_om_r1.pdf
I am using stryke AV15 MK2 para. that I converted and entered myself, so they may be incorrect. If someone has a program with the correct T/S paras. and could graph a closed angled box with 7200 in^3 volume and verify my results that would be great.
2)Am I going to be happy building this sub? I will certainly drive it to it's power handling capacity of 500 watts (that's for BOTH VC's, yes?)
3)from the owner's manual schematic, I am slightly confused as to what the schematic is describing that is right behind the driver, the larger rectangle is blank, and the two smaller rectangles on top and bottom are hashed out, what does this mean exactly? and slightly further to the right there's one solid line, and then in the very center a smaller horizontal rectangle that's blank. Again, the meaning of this?
Thanks for your help. Any comments you may have on this project that you would care to share would certainly help me out
Daniel
Daniel
