Bradford_M
- Nov 24, 2002
Just got a new Sherwood RD-8108. Wanted the DD and DTS decoding. The specs looked great with 6.1, DD EX and DTS ES, etc, etc. I have owned a Sherwood RV-5030 prologic receiver for the last 7+ years. I'm concerned because the 8108 has very little bass response. Tried all the settings I could find from the manual, but my old Prologic still sounds a lot better.
I have floorstanding Klipsch KG 3.5's and a matching center speaker. Planning to add rear surrounds after the recevier issue is resolved. Never needed a subwoofer because I always got plenty of "thump" from my setup. I will say that I was able to set a loudness switch on the ProLogic receiver to boost the bass and it has separate controls for treble and bass.
Is this inability to set and contol treble and bass to the same degree common on all new receivers today? Or did I just buy the wrong one?
Do the manufacturers all assume you will have a subwoofer?
What do you think my best options are?
Sorry for all the questions, I'm just really frustrated right now. Thanks in adavance.
Brad
Brad
