seth_petry_john
- Oct 12, 2003
This is such a great place... you guys rock! I have a question for the calibration people out there:
If a TV has multiple inputs of the same type, i.e. component video, can settings obtained by calibrating one input be applied to the other input(s) with the same results?
I have a Toshiba 57h82 TV, and I recently purchased the DVE calibration DVD. Using this DVD I have calibrated the ColorStream 1 input, which is the component video input used by my DVD player.
I also have HD digital cable, which I have connected to ColorStream 2, the 2nd component video input on my TV. The TV stores independant settings for each input, so I need to calibrate ColorStream 2 as well.
My question is... will I get good results if I just set ColorStream 2 with the same settings I set on ColorStream 1? Or should I actually plug the DVD player into ColorStream 2 and go through the whole process again?
I understand that settings obtained for an S-Video or composite video input won't apply to a component video input and vice versa.
Thanks in advance,
Seth
Thanks in advance,
Seth
