Max Jacobs
- Dec 18, 2001
the picture
Here's my entertainment center. It looks like I'm getting a magnetic field from the power supply of my A/V receiver (Denon 3801), which is causing a distortion spot to show up on my TV (JVC 27" tube). I don't think it's the other components, since none of them pack the power of the receiver. The speaker shouldn't be causing it, since it's a shielded center channel (Energy Encore).
The diagram does a better job of explaining it than I could. The power supply of the receiver is on the left-hand side of the case (looking from the front), so it is pretty close to the TV tube. Moving the receiver is not really an option (unless it's my only one).
I'd like to shield the receiver, if possible. I was thinking of getting a piece of sheet metal and bending it into an "L" shape. I'd place it so that it was between/under the receiver and the TV. Does anyone have any input on whether or not this will work? Does anyone have any better ideas?
Thanks!
-max
Thanks!
-max
