thom h
- Mar 25, 2008
- thom h
Hello, I own a Onkyo TX-SR805 receiver. Hooked up to it, i have Polk rm6751 speakers. The cable box, is hooked up HDMI, the Receiver to TV is HDMI. I have looked and looked online here and other sites and i just can't seem to find the EXACT answer to my problem. The subwoofer doesn't seem to be working. Here are the settings:
The subwoofer is powered and has a L and R output, the RCA jack comes out the L and is plugged into the subwoofer input R which is just under the "center" L input. The phase is set at 0, and the low pass knob is maxed out at 160Hz. The volume is set at half, the auto on is set to ON because i have it plugged into the receiver. Those are the setting on the physical subwoofer.
The receiver settings ...
under speaker config is ...
Subwoofer ... yes
Front ...... 120 hz
Center ..... 120 Hz
Surround ...120 Hz
Surr Back ... None
Surr Back Ch ---
LPF of LFE ... 90Hz
Double Bass ... Off
If you need more info let me know, I admit right now, i don't have a big amount of knowledge when it comes to the fine tunings of Surround Sound. The equalizer is Audyssey. To my knowledge this is not a THX speaker system. I have the audio presets set to THX Cinema for all TV channels (HD or standard), DVD, and game components. Someone, please help me fine tune this stuff so i can get the subwoofer working, and to get even better sound than what i have now. I do know for a fact that the subwoofer does work, just a setting or two is wrong......
Thanks in advance for the help.
Subwoofer ... yes
Front ...... 120 hz
Center ..... 120 Hz
Surround ...120 Hz
Surr Back ... None
Surr Back Ch ---
LPF of LFE ... 90Hz
Double Bass ... Off
