Hey guys, this is my first time here on the forums although I signed up a while ago.
I need help w/ some settings on my Klipsch Sub-12 Subwoofer.It seems as if its just not hitting right for some reason...
I have the Lowpass (Hz) set to 80hz and the gain is in the top middle. There is a phase switch that has 0 Degrees and 180 degrees what should this be set to? Also I have the Monster Cable 600 Subwoofer wire. It comes with a Y adapter to send the signal to the Left and Right inputs of the sub... should I use that or just put it into the Left LFE input? I have an Onkyo TX-NR901 Reciever, there are so many settings i just cant get the sub tuned right. If it helps, my speakers are
Front : Klipsch Synergy Series F-3
Center : Klipsch Synery Series C-3
Surr : Klipsch Synergy Series S-3
If anyone can help, please do. Thanks
-Raheel
-Raheel
