I am looking for a LCD or plasma that fits in our entertainment center that is 38.5" wide. What I figure is any 37" LCD/Plasma with speakers on the bottom or detactable will fit. I need some advice on what I am looking for an what brands are going to give me the best for the money. I have looked around a bit but going store to store is hard to tell what sets have the advantage. I really want crisp lines. I have seen some sets that have the "fuzzy edge" that I don't like I am willing to spend a little bit more.
I have been impressed with the samsung 40" LCD but it doesn't fit and I don't think they make a 37" version. I was also looking into the Protron 37" that sears sells - The specs look really good when comparing the brightness, speed, contrast ratio, and native resolution.
I am really at a loss here and would like to make a decision on brand and model then I'll look around for the best price. Thank you for any help you can provide.
Kevin
Kevin
