Luis Gabriel Gerena
- Jul 18, 2000
Hi!
I live rented so I can't use a regular AC so I went to K-Mart and saw a portable AC that has 9000btus. It says that the room size should be 10'x9'x8'. My room is bigger than that 14'8" x 10'4" x7'8 ". My normal HT room temperature is 83-86ºF and after 2 hours of operation (using my projector) sometimes it can go as high as 98ºF (when is a really hot day) but normally is around 93º. Heat is a killer for my projector so I would like my temperature to be as close to 80º as possible. Is it possible for this 9000btus unit to deliver in my room?
Regards
Regards
