Eddie O. L.
Good day all. Glad to have found a forum to interact with as I start this journey. The basics of which are this. I have a rec room upstairs above my garage (12'x19'x8'). We moved in 10 yrs ago and now i think its time to change it to a theater room. Im not looking for a high end $100K room remodel or anything. Mostly want to convert it with as little disruption to the room as possible. My next steps will be to find an electrician to do the low and high volt wiring. In the meantime Im starting to look at the equipment and have a question regarding projectors. Im trying to find out from those that have seen both if there is a big difference between native 4K and the tech using Faux-K (Specifically the Epson's with eShift technology)
With everything quarantined its gong to be hard finding a place to go in and see them for myself so I thought i would start here. Has anyone tried both and noticed a big difference? And did it matter what you were watching (sports, vs gaming vs BluRay)? Any guidance would be appreciated. Thanks
