Dre Witt
Grip
- Apr 16, 2000
The Sony tech just left my house... I was having a problem with RGB ghosting/separation in the far right inch of my TV screen. He went into the service menu and pulled up the convergence screen and was equally as shocked as I was!
All the red vertical lines on the right 1&1/2 boxes were skewing up at 45 degree angles in the top the screen and down in the bottom half. It was doing the same with blue also, only the reverse, pointing down about 20 degrees in the top half and up in the bottom half! The only thing working right was Green! It got worst the closer you got to the corners.
He tried to straighten the lines but couldn't work it out. He said he could make it look better but I had a "Pro Eye" and that I wouldn't be happy. Just return it.
I just got off the line and they're shipping a new one to me in the morning. (Why'd I buy on the Internet!)
Has anyone seen this problem before on any of the Sonys! I'm afraid the second one will show up and be the same!
The picture is awesome otherwise... If it wasn't for the that right hand side of the screen!
Dre
Dre
