Gary TP
- Sep 11, 2002
Can anyone recommend a good dimmer switch to work with the MX-500... I have 2 light switches i'm going to replace with dimmers and I want to be able to press a button to fade up and fade down full or just a little bit if I choose...I am willing to go whatever route whether that means getting an IR to RF or x10 type solution.
The reason i'm asking is because i've heard of issues with Lutron dimmers requiring a "hold" command to dim the lights or raise them to a certain level and the mx-500 doesn't support this...
It would also be nice to be able to set percentages of dimmness, but that's not necessary since i'm going with the least expensive type solution here...
