MarkHastings
- Jan 27, 2003
My company has asked me to create PAL DVD's, which I've successfully done, but now I need to find a way to test them in house (instead of at another facility that does PAL DVD conversions).
They are buying a multi-standard monitor, but I need to recommend a multi-standard DVD player and have no idea what exactly I need to be looking for.
I just need playback capabilities, so I don't need anything high end - I'll probably be hooking the machine up via composite and analog audio, so I don't need any high end digital outs or converters.
My first question is: In looking online, I didn't find any "Multi-Standard" players, but I did see "Universal" players. Is that what I should be looking for?
Secondly, I did see a universal player that will read both NTSC and PAL, but it said that you don't need a PAL monitor. I assume that means there is some standards conversion in the unit that send out an NTSC signal regardless of the source. I don't want to go this route - I want one that sends out a true PAL signal and a true NTSC signal (depending on the disc) and letting the mult-standard monitor do the switching.
Any ideas? thought?
Thanks!
Any ideas? thought?
Thanks!
