Aaron H
- Jun 28, 2001
Anyone here running a Tivo thru a modulator? I guess my basic question is how do you get 2 outputs on the TIVO to be active at the same time? I assuming that when you select the output to be used in the Tivo setup, that's the only one active? Or am I wrong?
I have the s-vid outs on the tivo going to the TV. I assume I either need the composite or coax out of the tivo to also be active so they can go to the modulator. Is this possible? How are others doing this?
Thanks, Aaron
Thanks, Aaron
