leodavinci
- Jan 8, 2007
- Jon
Here's the situation: We have a 2006 Mitsubishi WD-62725 DLP HD TV and I'm trying to connect a PS3 to it via HDMI. I had thought that this hookup would be a no-brainer. After all it's a HDMI to HDMI connection, and my TV has the NetCommand interface. Just add a device (in this case a game system) to the menu and you're good.
But noooo.
For about 40 mintues I played with NetCommand trying to configure and set up a device that would display the PS3. Nada.
Finally gave up and called Mitsu customer service and waited...and waited...and waited. When I got someone (a young, I presume, Indian lass, I also presume from her slight accent), we had to go thru the whole rigamrole about who I was and what TV I had, etc., etc. Then we spent several minutes going thru exactly the same NetCommand device setups I had done on my own.
No luck this time, either.
After about 30 minutes of this she realizes this isn't working and informed me she would put me on hold to pass me along to their second tier of customer service. And I waited and waited.
After about 15 minutes, I used their automated phone system to leave my phone number for a call back. Supposedly I won't lose my place in the que, but I kind of doubt it since it has been about 24 hours since then.
It could be the PS3. It does work as we had it connected to this TV via the A/V connectors on the front of the TV.
It could be the NetCommand interface doesn't recognize adding a game device via the HDMI connection.
It could be that our TV is not HDCP compliant, although it is a 2006 model we've had since late 2005. I was under the impression that HDMI meant something was HDCP compliant. I'm not sure now because the PS3 manual has a note that the PS3 won't work with non-HDCP compliant devices connected via HDMI. Huh?
So here I am.
Any thoughts, suggestions, recommendations?
Many thanks in advance.
But noooo.
So here I am.
