Daniel K
Grip
- May 25, 2006
- Daniel Koll
My sub sounds best placed on the oposite wall from my components. I figure I will just make my own cables to length and run them under the carpet. I already have a spool of 75ohm RG6, solid copper 3GH coax made by Perfect 10. I have some questions...
First, this wire is perfect, right?
Second, will these ends work?..
http://www.partsexpress.com/pe/showd...number=092-640
How are they put on? It says no soldering, are they the twist kind? If they are crimp, would soldering be a good idea anyways, all I have is 60/40 electronics solder.
Finally, I am going to need a y-adapter at the sub (Velodyne CT-120). Obviously this I will just buy pre made, will this be good?..
http://www.partsexpress.com/pe/showd...number=181-690
