Kevin C Brown
- Aug 3, 2000
Here's why I ask:
Let's say I have a 5.1 system. Let's just consider the surrounds.
Now, I upgrade to a 7.1 system. If I use the same speakers for the rears as the surrounds, I have effectively doubled the woofer area. Does that help low freq extension? (Any rules of thumb for that? 1/4 octave extension for doubling tha area, for example?)
Or does it become less clear, because if the pre/pro lowers the overall volume of *each* of the surrounds+rears speakers vs the original surrounds to maintain the same sound stage in the back of the room, I effectively get no or not much benefit? (Even though I still have double the woofer area?)
The real reason why I ask, is that I have full range towers for my surrounds now (for 5.1), but I'm considering going to 4 matching bookshelf speakers for 7.1.
With the 4, I get a better *timbre matching* back there, but should I worry about low freq? Maybe not anyway, because I crossover even now at 80 Hz, and the new bookshelves have a -3 dB point of 65 Hz.
Just curious what others think...
