David_Wong
- Aug 3, 2003
I have my equipment in a room that is not a regular rectangle which I believe is the reason why I'm hearing what I'm hearing.
Although I get a fairly stable stereo image from my mains, I always get a feeling that the female vocals of different recordings tend to emanate from left of center more often than not. I suspect my room has something to do with it. I will attempt to draw my floorplan as best I can using ascii:
_________________________________
|...LSP....................RSP...|
|........................................Door
|............... LP......................|
|________ Opening A ____ Opening B_______|
I do my critical listening from LP (Listening Position). LSP and RSP are my left and right speakers respectively. I keep "Door" closed for critical listening. Opening B is the doorway to the dining room, and has no door attached. Opening A is an opening about 3 ft from the floor, going up to the ceiling, it's about 4.5ft wide.
The speakers are 6 feet apart. Distance from speakers to back wall is about 3 feet, to front wall about 13 feet.
LP is about 9 feet from either speaker. As you can see, LP is closer to the left wall than the right wall by about 4 feet. Also, Right speaker is firing directly into an empty doorway (no door attached), but Left speaker gets some reflection.
Okay, the room is far from ideal but this is all I have. I live in a small apartment and this is the living room. I cannot move the right speaker forward and to the right because it will block "Door". I can't move it forward of the door because then it'll be too far forward.
Could anyone help with any tricks to beat this room? Or do I have to live with off-center vocals that I know should be coming from dead in front.
My speakers are Athena AS-B2s on 27" stands and they gave a really good image when I listened to them in the store.
