Don Morrison
- Jul 1, 2002
I have a Denon 2802 and have just bought a JBL nsp1 system and the PB12. My question is what kind of cables should I use to connect this. I have been told a standard "Shack" cable will be fine with a Y adapted for the dual LFE inputs. And my other question, is how long of a cable should I buy. I am not really sure where the sub will sit yet, but it probably be within 12 ft or so I figure. Is buying a longer cable just in case a bad idea? Does a longer cable create some problems??
