jayncal
- Sep 25, 2011
- Jay
Hello all, My wife bought me the LG LHB 336 HTiB and I have a few questions- I am planning on running the speaker wire for the rear speakers under my carpet (Running the wire through the attic won't work because my living room has a vaulted ceiling). I was planning on using flat speaker wire so I the wire can't be felt through the carpet. What gauge wire should I use and what brand do you folks recommend ? My plan is to run the wire under the carpet across the room, then run it inside up the wall to where the speaker will be mounted. Do I need to choose a wire that has an "In-Wall" rating, since I will running it up the inside wall for about 6'? Will running the wire inside the wall near the house wiring cause interference ? Any input is greatly appreciated! -Jay
