Drew Bethel
- Nov 22, 1999
...and the plunger got locked in the downward creased positioned - only to release unexpectedly sending cold toilet water into my face. :b
To prevent further suction action, you can poke a small hole, perhaps a few holes the size of an average nail, in the plunger.
Wouldn't this just cause water to go shooting straight up at you everytime you plunge?
plunge?
It would really depend on how much water you have in the bowl... I mean our toilets are old and not one of those "piddly diddly" 3 oz toilet but more of a manly 1/3 to 1/2 full jobbers so your plunger is always under the water, thereby preventing any backlash of water. However, for you people with newer water saving toilets, I offer the deluxe model, one with a built in splash deflector-injection molded onto the plunger head... Available in 5 premium colors (neon green, magenta, tye-dye, school bus yellow, and Clear for those of you who like to see what you're plunging) besides the boring red.
Call now and I'll send you a free 8-ball to put on top of the plunger!
jay
Do those pressure-assisted valves work with the new 1.6gal "low flush" toilets? I'm always having to plunge because the flush isn't "forceful" enough. I've always wanted one of those noisy public toilets in my bathroom. A loud flush is much less of a problem than a messy plunging job...
I'll have to check with my dad, but I'm pretty sure ours is a "low flush" toilet. When we got it, we got the whole toilet new, not just the valve, but I'd assume putting one on an older toilet would help out. The thing sounds like it will create sink-hole in the middle of your house, but it is SO worth it.
To prevent further suction action, you can poke a small hole, perhaps a few holes the size of an average nail, in the plunger. It wont really affect the plunger action enough but if it does get stuck in the down position, you should be able to slowly equilize the pressure inside and out so you don't get a facefull of spray!
I firmly believe Jay is McGyver!
