DeathStar1
- Dec 28, 2001
- Neil
I'm trying to improve the design of my animation site, http://www.ninjaturtlesnetwork.com. If you see the Current design, it's not exactly that great.
So, I started with this.... http://www.ninjaturtlesnetwork.com/test.php . I put a watermark menu on the top of the screen. Yet, for some reason when I try to add the layer that contains the data for my newspro text, the layer with the data dissapears. Any reason why this happens? I've also tried creating it using an HTML Template format and the same thing happens.
Also, is there any way using Dreamweaver to be able to link the menu items in the water mark?
