Tom Veillette
Grip
- Oct 8, 2004
Hey guys, I am going to need to replace my receiver soon, so I have been looking around. I'm a little unsure of what exactly would be the best option for what is needed. On top of that, if heard a few not-so-good things about a couple of the options.
Please keep in mind, price is a VERY big factor here.
New daugter will be coming sometime in the next couple of weeks, and I can't afford to spend too much. I don't have the cash some of you do.
Also, please keep in mind that I am coming from a 1997 or 1998 model Technics EX-510 receiver that has almost nothing. So pretty much ANY of the options would be a very substantial upgrade.
OK, so here are the options I firmly need, no matter what:
Component video up-conversion from composite and/or s-video.
Clean reliable power.
Reliability. (I can not afford to upgrade. This reveiver must last a good 5 years)
Usage will be 90% HT and console gaming duty, and 10% music.
OK. So here are my options, in order of price.
$270-300 range:
1. Sony 997B
Pro's: High Power
Good amount of inputs/outputs
Price
Con's: I've heard the reliability sucks
Also heard that power rating is way off, and I
should expect much less.
2. Denon 1705
Pro's: 3rd component input (which is very desirable to me)
Denon quality
Price
Con's: I've heard that power on this unit is also
overrated, and I should only expect 30 to 40
watts/channel.
Not as many connections as I would like.
Only 2 component inputs.
$350-450 range:
3. Pioneer 1014
Pro's: High Power
Many connections
High quality/reliability
Con's: Price
Only 2 Component inputs
$500+ range (550 or so online)
4.Sony ES 3000
Pro's: VERY high power
Many connections
Quality/reliability
Con's: Price
So there you have it. Those 4 models are the only ones I can find that have what I need.
Obviously, I would prefer either the Sony 997B or Denon 1705 due to the cost. I would most likely choose the Denon, even with the one less component input.
But, if the units do have the mentioned problems, than I will be FORCED to choose something higher priced. I can't really afford it, but....
And remember, whatever I go with needs to last a few years, no matter what.
Oh, and one last thing. The up-conversion feature is so important because my TV is a 27 inch Gateway Destination monitor. Everything needs to be sent from the receiver as component video into the component-to-VGA converter. So as you can see, the upconversion feature is a necessity.
So what do you think I should do?
$270-300 range:
1. Sony 997B
Pro's: High Power
Price
2. Denon 1705
Denon quality
Price
watts/channel.
$350-450 range:
3. Pioneer 1014
Pro's: High Power
Many connections
Con's: Price
4.Sony ES 3000
Many connections
Quality/reliability
Con's: Price
