John Pine
- Feb 27, 2002
- John Pine
The case of the unit only states voltage (3V) and the tip polarity (-) that should be used for an A/C adapter. The unit is a pocket size, and uses two AA batteries. I would like to use a 500ma multi-volt A/C adapter I have. Do you think this would be too high? A friend suggested 300ma instead. Any feedback?
