Dave_N
Grip
- Jul 3, 2001
My wife bought this $2500 POS entertainment cabinet from Ethan Allen a few years back. It's fine to house any 27" TV but I always wanted a 32". So, after about 6 months of searching I finally found a 32 incher that will almost fit. It is a Panasonic ct-32hx41. The only problem is that the set is about 3/8" too tall for the cabinet in its present configuration.
The solutions? Either I remove the TV tray (i.e., the turntable-like tray that allow you to easily swivel the TV to get to connectors in back), or remove the internal shelve unit and cut off 1/2" from the top of it.
Questions:
1. How much weight will that TV tray support? I think the ct-32hx41 weighs in at around 150 lbs.
2. If I remove the tray (big if since I have to figure out how to remove), is there any tricks on getting access to rear connectors? I do not have access to the back of the cabinet since it is very close to the wall with book shelves on either side.
Dave
Questions:
Dave
