Going to add a firewire card to my computer.
http://www.bestbuy.com/site/olspage....9&type=product
It also has USB 2.0 ports.
How easy is it to hook up? Does it just plug into
an empty PCI slot or do you also have to plug it into
a cable inside the computer?
Plugging into a PCI slot is easy. Hooking it up to
one of the internal power cables always confuses me.
