Todd K
- Oct 21, 2001
So in my bedroom, I have this really annoying stand up closet/cabinet thing that takes up a lot of corner space in a somewhat small room. I would just disassemble the thing and throw it out, but there's a hitch: My stupid landlady, when installing new carpeting in the place, decided she wanted to re-carpet the entire apartment, except for underneath the cabinet! So, if I were to remove it, I'd have like a 2.5' x 2.5' square patch of ugly brown carpet in a light gray carpeted room.
So, I'm wondering if there is any easy way to get a replacement patch for the carpet, and put it in so it looks reasonably normal? The patch will partially be covered by furniture, but I don't want it to stick out like a sore thumb.
I would appreciate any thoughts on the matter from the home improvement types.
Todd
p.s. also, I may choose to paint a small section of wall behind the current position of the cabinet. Is it possible (using the same color) to paint just a section of a wall and have it blend in with stuff that was painted a year ago?
edit: I have just conferred with some co workers, and I have been informed that trying just to paint a small area of a wall never works, you usally have to do the entire thing.
Todd
