Ryan Wishton
- May 17, 2003
I was wondering what do I need to download things from a VCR onto my computer and then transfer to DVD...
I used an Adaptec Videoh which seemed to work getting the items downloaded, but the problem is there is not enough time allowed... For example, you can only get about an hour at best quality for a DVD... You would be lucky to get 90 minutes at the lowest quality... It came with MySonic DVD software...
What I am looking to do is transfer my recorded tv shows, home movies, and things like that to DVD... But, I cant figure out how to put hours on a DVD... I know DVD's will give you up to 4-6 hours... Our Summer Vacation Videotape was 5 hours, so obviously 90 minutes on DVD is not enough at low quality... I would need 4 DVD's for one tape... Do I have to have a set top DVD recorder for the tv for these purposes???
Any help appreciated???
Maybe you can recommend some good software or equipment to use for this purpose and if I am doing anything wrong???
I am not the brightest when it comes to computer technical talk, so go easy on me... Thanks...
This is what I was using....
http://www.circuitcity.com/detail.js...&catoid=-10266
Adaptec VideOh! USB 2.0 DVD Converter/Video Editor
