This weekend I'll be hooking up a new TV with component video,should I go directly from my DVD player to the TV or route it through my reciever,what are the pros and cons of both. Thanks,Jim
Go direct, unless you use multiple display devices. Why would you even to take a chance on changing the signal? Just my opinion though!!
If you are close to your TV you won't notice any difference in video quality between direct connect and routing via the receiver. It then becomes a matter of being able to see onscreen controls etc.
------------------ Link Removed
If you only have 1 component-video device, there is no advantage to running through the receiver.
I like to run direct to the TV, but also run a composite video cable for every source through my receiver. This means the entire system can be run with just the receiver remote. This makes the system simple to use for the family/kids.
