RobP
- Apr 4, 2001
As listed above my dvd player is a Panasonic RV-31 and my receiver is the AVR 520. I keep having the same problem with these two units.
Here is the problem I am having. When I start certain Dolby Digital 5.1 dvds, althouth the reciever recognizes the 5 channels it only plays the fronts two channels. But it does not redirect any of the center or surround channel info. So I can tell things aren't right instantly. To fix the problem all I have to do is break the connection from the dvd player to the reciever by any means neccesary. I can do this by selecting a different input source on the reciever then switching back to "DVD". Or I can pull the optical cable and then reconnect it. If I do any number of things all 5 channels will kick in as normal.
I thought it could be a hardware defect but I am quite sure it is not because I exchanged the reciever for a new one and tested it with my brother's dvd player(same model). Sure enough I kept having the same problem.
This problem only seems to occur with certain dvds. So far I have found; The Matrix, Pink Floyd The Wall, & Armaggedon are three I have found so far.
It's not that big of a deal and I will live with it but I wonder if I am the only one who has experienced this.
Rob
Rob
