GregBe
- Jul 9, 2003
Please forgive me if my terminoloy is wrong. I am new to this.
Because I have satellite speakers for my fronts and my Denon receiver has a fixed 80Hz crossover, it has been recommended that I use the speaker level inputs as opposed to the line level inputs to my subwoofer. This makes sense to me, because I don't want to lose out on the signal from 80 Hz to 120Hz.
My big concern is loss of signal using speaker wire vs a good quality sub interconnect. The run from my receiver to my sub is very short, only 5-10'.
Is this the right setup, and is does it matter what type of speaker wire I use?
Also, if I do set it up this way, does it matter if I go from my receiver to my sub to my satellites; or should I wire both my satellites and my sub to the same post on the back of my receiver?
Thanks for your help.
