Jason_Chen_LA
- Feb 19, 2004
I'm in the process of setting up a 5.1 HT surround system. Here is a diagram of the room size and layout:
http://www22.brinkster.com/seafan/temp/ht.jpg
with the position of TV and sofa shown in the diagram, the brick fireplace next to the sofa presents the problem. from what I read, the ideal position for surround speakers is about 2-3 feet above ear level, on the side, which is position #5 and #6. this would work if the speakers are monopole, but the surround speakers that go with the fronts maybe bipolar speakers.
In that case, Position #5 would not work - it's right next to the brick wall of the fireplace. because of the open doorway#1, the next possibility is Position #3 & #4, which are 4 feet behind the sofa - is that too much behind the listening position for bipolar speakers? and for P#3, the sound waves would hit the fireplace brick wall 4 feet away on one side, and the open doorway #4 on the other - would that be a problem?
or, I could put them above open doorway #1 (7 feet high), at position #7, and P#8 on the other side. would that be too high? would P#7 too close to the brick wall (2 feet)?
Position #1 & #2 would be the back wall, and none of the info I got so far suggests to put bipolar speakers on the back wall.
Given the configuration of this room, should I avoid bipolar speakers all together, and get a pair of monopole speakers so I could put them on the sides of listening position?
thanks!
Jason
thanks!
Jason
