BrianGC
- Aug 19, 2002
Hi,
How do sets with video inputs that accept different input formats work exactly?
Say the input has regular composite and it also has either S-video or Component for the same input. If I was to hook up a VCR to the composite and then hook the video signal from a DVD player to the same input through either S-video or Component (w/ audio going directly to receiver), how would the set handle that?
Do the sets like that work ok with the 2 different input types plugged in at the same time, with only one live? And what happens if you're watching a DVD and the VCR were to be turned on, would it stay on the DVD or just go crazy?
BrianGC
BrianGC
