Kevin Trainor
- Jun 28, 2004
Someone please help me out with a very frustrating problem. While in Satellite TV mode my entire system powers down appx. every 1/2 hour. The satellite receiver is a Samsung SIR-TS360 (HD Receiver). System shutdown only occurs while in Satellite mode....DVD viewing is uninterrupted. My satellite receiver is hooked up to an InFocus Screenplay 5700 via the DVI/MD1A connector, and a Denon AVR 3805 receiver. Controlling the entire system is a Crestron AV2 Audio/Video Control Processor and STX 1700 touch pad. All components are plugged into a Panamax Max 5100 which is hooked into a 20 amp dedicated line. I should also mention that the lights are controlled via X-10 Powerhouse light control.
Powering the the front 3 channels is an Anthem MCA 30. Speakers are Def Tech BP 7001s, BP3000, and BPX surrounds (4).
I disconnected the Samsung receiver and hooked up to another TV in the house and it performs fine. I'm at a real loss for a solution especially when the Sat receiver was isolated and performed fine.
Kevin
Kevin
