bernard&*
- Mar 1, 2004
hello,
Any one who have a knowledge on this.Here in Philippines we use 220v/60hz voltage source.But the PE plate amp 300-794 indicate 220v,50hz and 115v,60hz.Do you think 220v/50hz do fine here?(Located at the lower right side of the amp panel where the voltage supply input is,PE provide a picture for some part of the amp). help pls..:frowning:
