HowardGjr
- Mar 14, 2002
I'm a "newbie" still looking for a receiver or pre-pro/amp. Suggestions? My original plan was to go with Integra DTR 6.3. However, it's delayed released made me consider some other options. Right now I'm leaning toward the Rotel RSX-1055. I liked the RSP-1066/RMB-1075 combination but I think separates is overkill for my situation.
Room:
1. Irregularly shaped. Approximately 14x14x8.5, carpeted with plaster over wood lathe walls and significant amounts of upholstered furniture. Large Bay window prevents totally darkening room.
Equipment:
1. Gallo Micros (5)
2. Gallo Passive M1 Subwoofer (1) (more like dedicated woofer for Front L/R micros)
3. Gallo Active Subwoofer MPS-150 (1)
4. Sony SCD-222ES (1)
5. Integra 7.2 DPS (1)
6. Outlaw ICBM
7. 32" Sony WEGA TV
8. Dedicated 20 Amp Service.
9. Radio Shack switches for DVD-A and SACD.
Criteria:
1. Reasonably sane remote control interface (WAF)
2. "Good" relatively warm Sound within limitations of small sat/sub system.
3. Relatively low power requirements. I don't listen at high volumes and Gallo's are efficient.
4. AM/FM Tuner
5. Dolby Pro Logic II
6. Adjustable crossovers -- Micros don't do too well with 80 Hz Crossover.
7. Receiver cost < $1500
8. Prepro/Amp/Tuner Cost < $2500
Possible Short Term Upgrade plan: months)
1. Gallo Due' to replace front three micros. Micros get moved with passive sub to reading room.
Medium term Upgrade plan (about 1 Year):
1. Plasma TV -- room not dark enough for projection and too small for RPTV. Need Plasma's to drop in price.
2. New Front (L/C/R) Sound-stage; most likely something in B&W line. The speakers will occupy some of the space vacated by the hated entertainment center.
3. Maybe a new sub...depends on how old sub sounds with new speakers.
Damn...all my posts are way too long. :b
Room:
Equipment:
1. Gallo Micros (5)
6. Outlaw ICBM
7. 32" Sony WEGA TV
Criteria:
4. AM/FM Tuner
