Blake Murdoch
- Jan 1, 2001
I'm sure everyone knows about the problem with an HD source going to a Toshiba 4:3 TV. I heard about a device coming from Toshiba that would convert the image into a proper widescreen 16x9 image and not stretch it to fill the screen. Here in Canada none of our STB's will do it for you. Here is there response to the device I was asking about.
"Hello:
Thanks for your inquiry on our HDP-1. The HDP-1 is expected in sometime around the end of March. We will be able
to supply a more realistic date closer to that time. The HDP-1 is in the testing stages now. From my understanding, it will reformat the HDTV 16 x 9 signal for a 4 x 3 HDTV-Compliant TV. By using 270 scanning lines it will create black bars and 810 scanning lines will be used
for picture information. It will correct the geometry of the 16 x 9 picture for display on a 4 x 3 aspect ratio TV. It will also provide a "cropped" version. This will fill the 4 x 3 screen with picture, however, you will loose some picture information from the edges. It will also perform a raster shift. This means that when using the black bar version, it will slightly shift the picture up and down to reduce the risk of raster burn. Pricing will be very reasonable to our customers only. Trust this information helps. Keep in touch. We will be pleased to provide
up-to-date information closer to the above mentioned date.
Regards,Norma
Customer Service"
Didn't know if this was well known or helpful/interesting for anyone.
Blake
"Hello:
Regards,Norma
Customer Service"
Blake
