LDfan
- Nov 30, 1998
- Jeffrey
Hi,
I just got my HD cable box. It's a scientific atlanta 3250HD unit. The rep from Cox cable said I have to hook up both the component video cables plus also hook up the regular composite cables in order for it to work. That seems kinda odd. Does anyone know why they would say that I would need to do that? So far I've only hooked up the box via the component cables and it works fine so far.
Does using the regular composite cables give a better picture for non-hd channels?
thanks,
Jeff
thanks,
Jeff
