JakubH
- Aug 15, 2002
I am looking to purchase a new receiver sometime in the near future. Being that I am in Canada, some of the prices/deals I can get are not as good as in the US. To give an idea of my setup, I am currently using an old Carver HR-722 60WPC reciever in stereo with ACI Spirit (AKA Opal) floorstanders. The Spirits are sealed 2 way using a Vifa tweeter and 8" Vifa woofer. They are a relatively easy load, althought not particularly efficient, and can soak up a lot of power. When I get the new receiver, I will also add 3 Optimus LX-550s as rears, and the rest as my pocketbook allows. EDIT: Forgot to mention that usage is essentially 50/50 Music/HT.
I am essentially looking for a few main features, it would be nice to get all of them but not essential. I want to have HD component switching (for my HDTV), as well as pre-outs for at least the front (I have an external line-level Paradigm active crossover that I intend to use down the road). I would like to have plenty of power on tap, at least as much as I do now, although more is always better. The receiver must have DPL II, and/or Logic 7.1, Circle Surround, NEO6 etc would be a nice bonus. I am not that concerned about having full 7.1 or 6.1 sound.
Based on these criteria, and prices I have been able to find, I am so far looking at the following choices:
1. H/K Avr-320 (~$950 CDN shipped from Ecost in US)
Pros
- lots of formats
- full preouts
- build/sound quality
- EZset remote
Cons
- top end of my budget
- no warranty (shipped from US)
- relatively low power
- not sure on bandwith of HD switching
2. Panasonic SA-HE200 (~$860 CDN)
Pros
- Lots of formats
- Lots of power on tap
- Specs better than SA-HE100 which tested extremely well in S&V
- 50mhz HD switching
- 24/192 upsampling (big deal?)
- Full warranty support
Cons
- No preouts (there is a tape loop though, and the extra power might make this less of an issue?)
- crap remote
- Panasonic name (psychological)
3. Pioneer D-811s (~$550 CDN)
Pros
- Lots of formats
- Full preouts
- cheap enough that I can soon upgrade to a nice 2 channel amp for the mains
- full warranty support
Cons
- only 27mhz component switching (is it a really bad thing?)
- pioneer name (psychological)
Given this breakdown, how would you all go about deciding? Would you choose something else altogether? Any insight/comments from owners of the listed gear or similar gear would be much appreciated. Thanks in advance.
Pros
- lots of formats
- full preouts
- EZset remote
Cons
Pros
- Lots of formats
Cons
- crap remote
Pros
- Lots of formats
- Full preouts
Cons
