marc paolella
- Jan 1, 2003
I just got my unit and wired everything up. All is well and everything sounds good. However, I made a disturbing discovery when I tried to hook my Game Cube to the front inputs (Input 4). The sound is fine. But there is no video. So then, I tried my camcorder as a second check. Still get sound, but no video on Input 4. Then I tried the S-Video port on input 4 instead of the composite. Bingo, got a picture.
So then I tried other ports and discovered that none of my composite inputs are functional for video. However all the S-Video inputs work fine.
First of all, has anyone had this problem?
Second, is it worth solving? I use S-Video or Component inputs whenever possible. And S-Video to RCA adapters are a dime a dozen, so I can always workaround this problem if I need to connect an older component with composite only outputs.
I've got the damn thing wired for 7.1 and I bought the AVR at B&H in Manhattan, so it means disconnecting everything and shuffling back into Manhattan (an hour drive). Yuk!
-Marc
-Marc
