Craig Ball
- Oct 6, 2000
I can't figure out how to get my H/K 520 to emit a test tone from the rear center speaker. Help
Craig
Craig
If this 6th channel shows up, I would try activating the manual test tones (also in the 'channel adjust' menu just below the dB readings) and see if you can't produce a test tone that way. If you can, you can always use the SPL meter in the remote to manually adjust the levels.
Thanks, i'll give it a try.
Craig
