Sonnie Parker
- Dec 11, 2001
I've got a great amp for a remarkably low price. It will power either one (bridged) or two (stereo) subs. It is a great match for any non-powered sub and you would be hard pressed to run out of steam with this one. No doubt it will do the job.
Peavey GPS 3500. Here's the specs:
Features
1750 Watts RMS per channel
Initialization protection
Peavey Exclusive DDT™ speaker protection
Dual variable-speed cooling fans (very quite)
5-year warranty
Specifications
Output Power:
Bridge Mode, Mono
4 ohms: 3500 Watts, 1kHz, 0.1% THD
8 ohms: 2400 Watts, 1kHz, 0.1% THD
Stereo Mode, both channels driven
2 ohms: 1750 Watts per chan, 1kHz, 0.1% THD
4 ohms: 1200 Watts per chan, 1kHz, 0.1% THD
8 ohms: 775 Watts per chan, 1kHz, 0.1% THD
Rated Output Power:
4 ohms: 1050 Watts per chan, 20Hz to 20kHz, 0.1% THD
8 ohms: 750 Watts per chan, 20Hz to 20kHz, 0.08% THD
Slew Rate:
Stereo Mode, each channel
40V per usec
Bridge Mode, Mono
80V per usec
Input Sensitivity & Impedance:
@ rated output, 4 ohms
1.62V RMS (+4.2 dBV)
Unbalanced, 1/4" phone jack
20K ohms
Balanced, XLRs
(polarity selectable) 10K ohms per leg
Overall system gain per channel
40X (+32 dB)
Frequency Response:
stereo mode, both channels driven
+0,-1 dB @ 1 WRMS, 4 Ohms
5Hz to 100kHz
+0,-0.2 dB @ rated output, 4 Ohms
10Hz to 30kHz
Damping Factor:
(Typical Value)
8 ohms, 1kHz
Greater than 325
Hum & Noise:
Stereo mode, both channels driven
Below rated output power, 4 ohms
100dB, unweighted
Power Consumption:
@ 1/8 rated output power, 2 ohms
1400 Watts @ 120 VAC
The amp has been removed from the box but never connected and never plugged into an outlet. It is brand spanking new. I financed this unit along with some other equipment for a fellow who would not pay. He actually had some of the equipment at my office building (in a spare office) while he was remodeling and until he got time to install all of it. Well, he never made the first payment and I wouldn't let him have the amp until he did. Ended up repossessing the unit. The dealer tells me dealer cost is $900+ and it is very hard to find Peavey products at huge discounts (can't find any on the web). I am willing to let the amp go for $800 plus shipping. This is very reasonable.
You can contact me by e-mail here or call me at my office toll free 1-877-566-6004 on Mon/Tues/Thur/Fri...from 9am til 4pm CST. I'm in Troy, Alabama 36081.
SP
Features
5-year warranty
Specifications
Output Power:
Bridge Mode, Mono
Rated Output Power:
Slew Rate:
40V per usec
Bridge Mode, Mono
80V per usec
20K ohms
Balanced, XLRs
40X (+32 dB)
Frequency Response:
5Hz to 100kHz
10Hz to 30kHz
Damping Factor:
(Typical Value)
8 ohms, 1kHz
Greater than 325
Hum & Noise:
100dB, unweighted
Power Consumption:
SP
