JoelAJ
- Sep 20, 2000
Brand new! GBA - TV Converter. Multiple quantities available.
Wish your GameBoy Advance were backlit? Yeah, that'd be great. How about a bigger screen, like twenty-seven inches or so? Well, lucky for you I have then GBA-TV Converter. The idea is simple: a device that lets you play your GameBoy Advance games on your television, and in practice it's not that much more complicated.
The GBA TV Converter is split into two parts: a white interface shell that replaces the back of your GBA and a converter pack that connects to your TV. The interface shell links directly to the screen of your GBA and can either mate to the converter pack for TV play, or stand alone and keep the system portable.
The whole thing works rather well. The image and sound are transmitted via stereo audio, video or s-video connections. When hooked up, the image shows up on both the TV and GBA screen. While running through to the TV, you have a choice of full screen or smaller to preserve picture quality, which does suffer a little bit by the enlarging process. Sound, however is awesome. You never knew how good the sound effects and music were on the GBA until you've heard them through actual speakers.
The GBA TV Converter comes with the interface shell, converter pack, AC adapter and both "+" and "Y" type screwdrivers (for removing the casing and applying the shell).
-GBA console need to be slightly modified - just remove the back of the GBA console and replace with the supplied back replacement case.
-No need for soldering.
-Directly connect to the TV or monitors and play.
-High performance video display quality and PCM sound system.
-Supports normal AV or S-video
-Bundled contents:
1. TV Adapter.
2. Back replacement case.
3. AC adapter.
4. Tri-wing screw driver
5. Cross-wing screw driver
$50 inluding shipping
Paypal (from balance or bank account) or USPS Postal Money Order!
Actual pictures:
Components and instructions
Actual screenshots:
Super Mario Advance 3: Yoshi's Island (#1 Full Screen)
Super Mario Advance 3: Yoshi's Island (#1 Small Screen)
Super Mario Advance 3: Yoshi's Island (#2 Full Screen)
Super Mario Advance 3: Yoshi's Island (#2 Small Screen)
Super Mario Advance 3: Yoshi's Island (#3 Full Screen)
Super Mario Advance 3: Yoshi's Island (#3 Small Screen)
Tetris World (#1 Full Screen)
Tetris World (#1 Small Screen)
-Bundled contents:
1. TV Adapter.
3. AC adapter.
Actual pictures:
Actual screenshots:
