bruin
- Nov 29, 2002
http://www.pbase.com/bruin/bl2_driver
I got this 12" DVC sub from someone on this forum. This is awesome and ear shattering. Too much for me. I'd like to get $225 obo for the driver or $350 for the sub. Compares to the 12" Brahma and its technology. It's in excellent condition.
Recommendations:
For home use:
Low Q Sealed music design => 2.5ft (~70L).
Ported: 3cuft tuned to 20hz.
For car:
Sealed stuffed: 0.7 to 1.5 cuft
Ported: 1.5 to 2.5 cubic feet tuned to 30 Hz.
This can handle up to 800w RMS (I only feed the other sub with 350w with a Rythmic Amp). In comparison to AV12, this driver has just slightly less Vd than the AV-12 (rated at 2.3Lea using the correct xmax in the calculation) but they do not have the power handing or linearity of this sub. The AV12 uses a conventional motor and this sub uses a very comparable motor to XBL2 for measurably more linearity. This driver has the extra cooling below the spider. This allows the coil to cool a little better on the upstroke.
If you want more in depth information I will forward your inquiry to the proper person.
Dimensions:
Cutout: 11.13"
Diameter: 12.5" ,Depth 7.3"
4ohm nominal, 3.04 ohm measured w/ DCR.
If you want to audition the sub or pick it up locally to save on shipping you can email me to arrange an appointment. I prefer local pickup. I'm in the Northridge area. If you want the driver shipped be aware it is about 40lbs so check out UPS.com for rates. I only have a 350W@4ohm amp to drive the sub but if you have an amp that you want to test it with you can bring it in. Thanks
Recommendations:
For home use:
For car:
Dimensions:
Cutout: 11.13"
