Tim Hoover
- May 27, 2001
I have a couple questions involving my replacing some minor parts in my '87 Mustang 5.0. I've tried reading through both the Chiltons and Haynes manuals and am about to give up.
#1- I'm trying to replace the PCV valve and simply cannot find the damn thing...
#2- I'm also SOL in locating the oxygen sensors. The computer at AutoZone said my car required 2, but the manual only gives a (poor) location of one of them.
I'm also experiencing a couple of problems with the vehicle, which may or may not be related to the above parts. First of all, the car tends to stall out when idling. I have to keep a small amount of pressure on the gas pedal to keep the RPMs up to prevent this. I'm also replacing the fuel filter, so this may solve that problem. In addition, my temp gauge is all over the place. I can sit at idle and the gauge indicates that the temp has gone up 40 degrees. When the car first warms up, the gauge goes almost 3/4 of the way up before settling back down to around the 1/4 mark, which in my experience is normal operating temperature. Why would the gauge be fluctuating so much? The main thermostat was replaced fairly recently, so I don't think it could be faulty...
