Mike Dr
- Jul 30, 2000
I just got the 1124p .. after hours of playing and trying to figure it out i think i got some results..
I used SpectraPLUS with radio shack spl meter as microphone. Did some graphs before then tried tuning .. my problem is i have a BIG dip at 32hz in my room .. (probably around 15dB if not more).. so I tried to bring the rest of the curve down significantly while bringing the dip up a little bit.. i got a flatter curve now but i dont know if could do better.... the other thing is setting it up .. its not the most user friendly interface so i figured I'll use the software. I have midi cables.. could not get the midi to work recieve OR transmit .. anyone have problems with this?
Also, new to this model is a different input level adjustmetn.. a -10dB and a +4dB .. which one should i be using?
and finally .. if i have a choice of raising the sub level in the Receiver (LFE level), in the BFD (assuming i got into the plusses) or the analog volume knob on the sub itself, which will degrade the signal the least/most?
any other tips will be very welcome
thanks
thanks
