GraysonAng
- Jan 9, 2004
Fluance AV-SC Center Channel Speaker. Costs $69.99 plus $20 shipping at www.fluance.com.
4.75 out of 5 at audioreview.com:
http://www.audioreview.com/Center%20...1_2743crx.aspx
Asking for $74.99 shipped, but make an offer.
Fluance speakers, the choice for audio enthusiasts around the world, are recognized as an outstanding performance product that delivers amazing sound, superb build-quality and unprecedented value. We have accomplished this by strictly adhering to a single goal:
Design and engineer speakers that ensure accurate sound reproduction at prices with which none can compete!
To achieve these goals, Fluance uses high-performance drive units, advanced enclosure technologies and highly refined crossovers to achieve all new standards in sound performance and technological design excellence. The results are clean, undistorted bass, smooth response throughout the midrange, exceptional high frequency resolution, and pinpoint imaging that everyone can appreciate.
When the principles are applied without compromise, you can close your eyes, open your ears and the speakers disappear . . . now you are at one with the sound!
High performance features include 5 way binding posts that are gold plated. This model is magnetically shielded to avoid interference with other audio/video products. They combine to produce the best sounding, best value performance speakers on the market!
They are the ideal solution for affordable high-end sound in your hifi music or home theatre surround sound system!
Description
A flawlessly made two-way technology center channel speaker system. In the listening environment this speaker gives an exciting performance. With superb sound radiation and rich timbre, it converts the audio signal into an incredibly wonderful vocal experience. In movies it actually seems like the actors are speaking to you in the same room!
Key Features
Center Channel Speaker System
Magnetically Shielded
MDF Wood Construction To Reduce Cabinet Resonance
Ferro-fluid Cooled Tweeter For Longer Life
Butyl Rubber Surrounds For Increased Durability and Performance
5 Way Gold Plated Binding Post Terminals for Optimum Conductivity
Banana Plug Compatible Connectors
Removable Flush Fit Grills
Crossover Features Butterworth Design
18 Gauge Lead Wire to Reduce Signal Degradation
Premium Black Ash Woodgrain Finish
New With A Full 5 Year Parts and Labor Warranty
Specifications
System Type: 2 Way - 3 Driver Center Channel Speaker
Tweeter: 1" Titanium Balanced Silk Dome Ferrofluid Cooled
Midrange: Dual 5" Polymer Treated with Butyl Rubber Surrounds
Power Handling: 10 - 120 Watts
Frequency Response: 70 - 20K Hz
Sensitivity: 88±3dB
Crossover Frequency: 3000 Hz Phase Coherent - PCB Mounted Circuitry
Impedance: 8 Ohms
Enclosure: Acoustic Suspension Design
Dimensions: 7.5 X 20.4 X 8.3 inches (H x W x D)
Weight: 13.7 pounds
Description
Key Features
Specifications
Sensitivity: 88±3dB
Impedance: 8 Ohms
Weight: 13.7 pounds
