Rolando
- Feb 19, 2001
I am fired up!
It got here last Friday and I have been so busy I have not had a chance to post for help.
First the geometry issue. It’s minimal. I mean no one in my household, living or visiting, has noticed but it is killing me. It’s in the center of the screen. It is slight but it look like it curves in slightly down in the center like an invisible string is pulling in down. Is there a setting in TV menu to fix this? Went through manual and could not find a way to do it. I did find the tilt correction and that helped. I was a little worried at first but after tilt correction if I can fix this I am good to go! If it cannot be done via the menu who do I call about this? Would the retailer be responsible for sending a tech? Or should I call Toshiba?
Now for calibration. First of all out of the box it’s really nice. Well once you take it off sport setting of course. But just going to movie it’s already wow! So I pulled out my DVE and I am having trouble. I don’t like the picture I am getting in the end. I am having a hard time setting the contract. Whether I use DVE or an old disc I had called Ultimate DVD platinum or even the THX optimizers I can never set it right. It says put up until it bloom then bring down but I can never tell.
I try to watch on movie setting which is not horrible but I can tell brightness is too high. Picture does look a bit washed out and blacks are NOT black. Using different set up disk it does guide me to bring down from 50 (as it is) to somewhere between 32 and 34. However it’s too dark. It’s as if it needs some contrast maybe.
Another thing is I feel it has a bit of a red push. Again using DVE seems color stays untouched and hue/ting barely goes to 6G for the blue and red to look perfect through the filter. However green never looks quite right through filter so left it at that.
I am considering ISF calibration but not yet as I still thinking of getting new player as well as HD through cable provider so will do it then.
In the meantime any suggestions?
